We have a private well in our home and I have a water question that I think this group can answer.
When I make ice cubes using the water from the well and then melt the ice cubes in a glass of the same water, small white particles fall out of the water and collect in the bottom of the glass. It's a slow process but if you leave the glass for a few hours you will find a white powder in the bottom. I had a neighbor do the same test and he had the same results.
I've asked around and the general consensus is that it must be calcium but I haven't tested calcium hardness of the water (it just occurred to me as I write this). Has anyone else ever seen this? Any ideas?
Mike.
EDIT - Correction - I meant to say that the white solid particles fall out of the ice as it melts.
Mike.
