Warrior impeller overload error won't go away and I cleaned the impeller
adamfrey
22
atlanta
Hello great gurus,
Got a new Warrior SI. Cleaned like a charm for a week....impeller got some stuff in it. I cleaned it. Hit reset robot but it still says impeller overload... I have called into Pentair but wasn't sure if there is something that I am missing? I can manually drive it all over the pool but won't run its auto cycle.
Hello Adam! :wave: I don't have a Warrior cleaner, but see that no one has replied to your post after over a week. Figured it was time to follow-up to see if you still need help to try and get this thread some visibility. Post back as much as needed.
Hey Adam !! Paging @IceShadow because IIRC he had a similar overload that was an electrical issue masked as an impeller issue. These fancy electronics can only guess so much. I hope he has ideas for you. :)
My main solution was contacting the manufacturer for a warranty repair. That should be applicable here I would think!
