So my pool builder installed a 3rd party led color changing light system and wired it into my EasyTouch as a basic on/off feature. This is fine, but they say it can't be controlled specifically under the light section of my screenlogic. To change the color or mode, you need to cycle on/off the power which doesn't work through screenlogic, mainly because the interface is too slow switching on/off the circuit.
So, I assume to use the "lighting" section of the screen logic, you probably need a specific pentair brand light. Yes? Do you also need a controller of some sort to wire into the serial bus of the easytouch? How does this all work?
THanks crew!
THanks crew!
