So I'm working out the equipment details with my PB and have some questions on how much a VSP would benefit me with an in-floor system. Don't want to debate the in-floor at all, I've done the research and heard all the opinions of robots but have decided to go with the in-floor anyways, for heating and cleaning purposes (vinyl liners should see more cleaning benefit).
My vision is that I get the VSP with an Easytouch system and have a valve controlled by ET that can isolate flow either to the floor system or the surface jets. My plan would be to run at high speed to the in-floors for about 4 hours a day to clean and heat, and then switch over to low speed isolated to the surface returns for another 4-6 hours for chlorine production and filtering (SWCG).
The PB mentioned that the Pentair VSP is not high head so it wouldn't work with the in-floor system. He owes me an answer on whether he means this is only if I don't have a way to isolate the surface returns then the low speed wouldn't work on the in-floors because it wouldn't have enough pressure to pop the heads up. With my plan to be able to isolate flow to the surface returns only when on low speeds via a valve controlled by ET, I'm thinking it would work fine and I would see some savings by doing it this way. Can someone validate what I'm thinking is correct while I'm waiting to hear back from the PB? They said they normally only do single speed pumps with in-floors, but I'm pretty sure they normally have the surface returns as one of the zones on the in-floor valve so there's not a way to isolate like I am suggesting they do with a separate run and valve.
