Tony'sPool
10
Wilton, CT
Hi All;
I was hoping one of the Jandy pro's could help me. I have a schedule set-up with my Jandy VSP and i'm running at about 1,000 rpm for much of the day and then about 4 hours at higher speed in the afternoons. i'm wondering if there is a way to set a one touch button so that I can run the pump at a higher speed while brushing and/or adding chemicals without changing my regular schedule? I hope my question makes sense and would love it if someone could help explain how i might do this.
setup 1 and 2 with your schedule. Then setup speed 3 with the speed you want. When you want it press 3, when done, press the button associated with the current time.
