Flow monitoring uses the flow switch in the SWG to detect a lack of flow so that the automation can shut off the pump if there's no flow. This protects the pump from running dry and getting damaged.
So, it still doesn't make sense. If the flow sensor was tripping to off, it could shut off power to the pump, but the pump would just shut off and not reduce and resume.
Maybe the flow switch is beginning to fail?
Check the flow indicator in diagnostics periodically to see if it's tripping off and on.
What speed are you running the pump where it's not closing the pressure switch?
Reducing the eyeballs might help if you're sure that the flow is good.
Maybe you just need to increase the pump speed.
Maybe the heater pressure switch is failing or needs to be adjusted.
If the heater is significantly above or below the pool, you might have to replace the pressure switch with an actual flow switch.
