- Jan 4, 2016
- 5,392
- Plaster
Well, I have to honest with you about test strips. If they will burn long enough to heat up a hot dog, that's about all they're good for, although I suspect the fumes might be dangerous. I'm not going to say a pool is safe based on test strips or pool store.
Chances are that you do have some CYA in the pool, that's good. If it were mine, I'd assume 40 ppm CYA for now. For that level, your minimum is 2 ppm FC for swimming, so safe in that respect. pH sounds fine as well (I'm ignoring the test strip).
So for using it this weekend, those are the aspects I would consider if it was mine.
The shock level for beginning to kill algae would be 16 ppm FC, which is 9 litres of 12.5% pool chlorinating liquid. If you won't be swimming, it would be fine to do that to get started on killing off the algae, but I wouldn't rely on it for considering the pool swimmable until you have a proper test kit.
The "4-in-1" test kit I'm thinking of has drop based testing. I've been searching canadian websites and everything shows out of stock (perplexing), but here's an example: 5-Way OTO, Chlorine/Bromine, Alkalinity, Acid & pH Pool Test Kit
