Vinyl Liner Is Sagging
caseyrichards
59
Berkeley Lake, GA
Is this a big issue and/or easy to fix? It’s just one small section at one end of the pool. And it’s above the water line which is good so water isn’t leaking back behind there into the ground. So really just want to address it aesthetically and be proactive. Thoughts?
+1. This time of year it usually doesn’t need much convincing. Massaging it back into place should warm it enough from the friction to be pliable enough.
They say to use a screwdriver, or preferably a popsicle stick to force the liner lock back in. I am too clutzy for that so I use a 2X4 block and hit it with a rubber mallet.
Thanks I'll give it a try. I may need to find a YouTube video of how to do all this! From what it looks like I think the problem is that the liner lock is completely missing in that section so that would make sense how it came out.
Any boat shop can fix those easily, You can also fix those using fiberglass resin and gelcoat :)
Sure, but how exactly would I get the stairs to them? It’s built in. Let me show you this wider photo so you have a better idea what I’m talking about. That Putty looks promising.
Reactions: PoolStored
They have mobile boat repair people... There are many people that will come fix fiberglass including some car repair people...
I think that pool putty will be much easier though :)
Reactions: caseyrichards
