VGreen 165 Digital Input unexpected priming behaviour
johnkim2020
80
Canada
Hi,
I’m using a VGreen 165 to run my water Laminar Jet.
Normally, I start it using keypad. I press start then Override at 1600rpm. This method skips the mandatory 3 minutes priming process because priming water flow is too strong for my laminar jet.
Recently, I hooked up to my automation and intended to start the pump using digital input 4(Override Mode).
Instead of starting without prime like manual keypad Override, the override in digital Input starts with the same priming process which makes my laminar jet shooting into my patio.
I researched this and came up with few option:
1. Add a VGreen 270 control panel because apparently priming RPm can be adjusted using this control panel. I don’t want to do this as adding $300 is a lot. I could’ve gone with a Pentair VSP at that point…
2. Modify the plumbing to add a return diverter valve. I want to avoid this because cutting and regluing pvc precisely at the correct length is a PITA… this won’t fix the problem because once priming is done, the laminar jet will be too pitiful at 1600rpm with diverter valve open….
Does anyone know any other way I can fix this?
