What is the main disadvantage of having a really low CYA level, besides needing to add chlorine more often?
When I tested CYA recently, I believe I tested at close to zero, if not zero. I have added some pucks to start raising CYA, but that is very slow (1.7 ppm per 8 oz. puck). In the meantime, my pH level is good and my pool is crystal clear.
What is the easiest method to raise the CYA faster, without using the nasty stabilizer that you need to dissolve in hot water over a period of a week? Is there a liquid stabilizer that I can just add?
Thanks
Chuck
Thanks
Chuck
