Hello everyone.
In the final design stages in my pool build and have a nagging question.
Current plan is to use a channel drain in the bottom of the pool with a single venturi skimmer.
From my understanding the vunturi skimmer pulls more GPM through the skimmer basket without having to increase the suction from the skimmer itself than a traditional skimmer. The literature I have seen states that one of the benefits is that you can pull more from the bottom drain of the pool and pull less from the skimmer to the pump and have the same cleaning capacity or better than a traditional skimmer.
On the flip side, I have also seen and played with the idea of not including the bottom drain as I have seen other opinions on the fact that the bottom drain doesn't do anything special beyond allowing the pump and filter to pull from a large source to turn over the water in the pool.
Thoughts or opinions?
