Hi,
I am looking for help to determine the appropriate variable speed pool pump to replace an existing, unpleasantly loud single speed.
Current set-up to be replaced:
Pool specs:
I am looking at the Pentair Superflow (1.5HP) or Pentair Intelliflow (3HP). Feed of head and flow rate seem to suggest to go with 2HP or bigger. I could not find any Pentair variable speed pump with 2HP. Other sites seemed to have suggest to go rather bigger than smaller to run the pump at lower load.
I am looking forward to your input on the sizing and recommendation for the pump (incl. alternatives to Pentair). Thanks in advance
- Motor: Century Centurion B855, 2HP
- Pump: looks like Star-rite Max-E-Pro
Pool specs:
- Separate cleaner pump
- Pool (19,000 Gallons) and SPA (with 6 jets)
- Min flow rate: 30-40 GPM (calculated based on 19,000 gallons/ 8-10hrs/ 60min)
- Max flow rate: 73 GPM (estimated based on 2 inch intake)
- Pool filter max flow rate: 150GPM (Pentair CCP420)
- Heater: min 40GPM and max 120 GPM (STA-RITE® MAX-E-THERM 400)
- Feed of Head: 67 (valves on skimmer intake and pool return) to 70 (SPA intake and SPA return); calculated based on measurements with vacuum gauge and pressure gauge at pump
- Distances to pump: Skimmer 1 = 25ft, Skimmer 2 = 50ft, Pool = 40ft
