I just recently upgraded to a Tristar VSP Pump with Hayward Pro Logic automation. I've been looking over the forums and have a ton of questions about this pump.
1. I was wondering if this pump can be installed with both the Hayward automation as well as the panel that came with the pump. Right now when I added the low voltage Com wire from the Pro Logic panel to the pump I disconnected the panel that came with the pump. Can both these be wired at the same time or is this a bad idea.
2.I have a Raypak heater. I was wondering what speed the pump should run when the heater is on? Does the speed even matter? Anyone have experience with the Raypak heaters and VSP? What has worked best?
3.I'm using a hayward chlorinator. I looked through the literature for this chlorinator and I may have missed it but I cannot find the minimum GPM needed for the chlorinator which would help me figure out the speed I need to run the pump.
4.I assume the VSP should be run at full for my polaris. Is this correct?
5.I've seen may thoughts on pool turnover. How may times should the pool turn over in one day?
Thanks for your time
