Vacuum Heads
HarryMichael
138
Baton Rouge, La.
Fiberglass
Hi..My pool cleaner does a great job at cleaning the pool, but for those times when I need to vacuum, my cheezzze little vac head does not do a good job. I have to move it "very" slow or it won't pick up and if I increase the suction, it sticks to the bottom (I broke it the first day). I was thinking of getting one of the heads with the wheels (25-35$ range). Seems to me I could increase suction a bit and the wheels would keep it from sucking itself to the bottom. What do ya'll think? Anything I need to know about them before I buy one?
Thanks..
It depends on the kind of pool you have. You need to be careful with a vinyl pool as the wheels can mess up your liner. I do not know the extent but I have read that before.
I have a plaster pool and have a suction vac. My pool does not get that dirty so I use a manual wheel vac to spot vacumn.
Thanks..
Hi Mate,
The best vacuum head for you is definately
the one with wheels. Just make sure that it
has a flexible body too...so that it bends in
the corners.
The one with wheels is actually my favorite 8) 8) 8)
Take Care,
Michael Silvester
