- Sep 7, 2009
- 391
- Fiberglass
- Pentair Intellichlor IC-30
The title does not lie. We vac'd a plastic thermometer. It is about 1/2" dia x 5" long or so. Went right up the vac line into the plumbing between the skimmer and pump. Needless to say I am quite concerned. So far, no change in pressure at the filter, and it is not in the pump basket. I also worked the hose quite a bit to see if it was still in there, and could not find it.
So do I.....
- forget about it.
- get a roto rooter type guy to smash it with a drain snake all the while pumping to waste to keep the mercury (or whatever it is) out of the pool water.
- fill the hole with dirt knowing that a pool is just not for me.
Thanks in advance.
So do I.....
- forget about it.
Thanks in advance.
