Vacation what to do with pool?
Absolutely, I didn't mean to make it sound like an algae outbreak is guaranteed. And I've never had to do a SLAM, but from what I read they sound like a lot of work, and a lot of expense. Better to pay up front and avoid the possibility altogether, I say...
i was just gone for six days and did 3 tabs in my pool with a solar cover. I put the floater under the cover in the deep end in front of a return because I wasn't sure how much it would move under the cover. Brought the pool up to the high end of the recommended level for my CYA before I left. My brother came and swam with his girl friend once while I was gone. Pool pump is on a timer and it was clear and the chlorine levels where fine when i got back. I left my CYA low this spring knowing I was going away for a while, but as others have said you can check the pool calculator to see how much it will effect things.
Probably went overkill with the number of tablets, but I'm peranoid.
