I am going on a week long vacation and would like to run my thoughts on a management plan by the experts.
Let me start by saying that I found TFP 3 yrs ago when I became a new pool owner. Fortunately, I found this site early and have enjoyed sparkling water since! Thanks!! I typically keep my chlorine levels at the upper end of the target range just for a little wiggle room (I prefer not to play near the edge). Last year my CYA was running at 70 so I could juice my chlorine up to SLAM level (28 ppm) prior to vacation and let it drift down to target range (10ppm). Assuming a chlorine demand of 2ppm per day and a SLAM level of 28ppm, chlorine levels would be good for about 9 days (28-[2*9] =10ppm).
This year my CYA is much lower, 30, which reduces the spread between SLAM (12ppm) and upper end of target range (6ppm). At 2ppm per day, I’m only good for 3 days.
I am considering raising my CYA to 70 using some leftover powdered shock. I realize this will result in a high SLAM level if I should need to SLAM, however if I manage my chemistry properly I shouldn’t need to SLAM!
Soooo, assuming I have a good handle on water chemistry and am in no danger of an algae bloom, is this an acceptable management technique? Am I missing something? Any downside?
