- Feb 11, 2024
- 78
- Plaster
- Pentair iChlor 30
I understand I should use a skimmer plate when connecting a vacuum hose to the skimmer to prevent clogging up the skimmer line.
When using the vac line on the pool wall and vacuuming through that, is there any kind of device needed to avoid clogging up that line? I haven't found anything for that, but it seems that would be susceptible to the same clogging. Do I just get a male to male adaptor and directly connect the rigid end of the hose to the receptacle on the pool wall and start vacuuming?
Thanks
Thanks
