Using well water to fill new pool
berger
0
Aug 11, 2015
16
Ellensburg Washington
I am preparing to install my new above ground metal pool. It is 21' round and 10,500 gallons, with a vinyl liner. I am contemplating using my well to fill the pool. I have tested the well water after running through an ECO ONE hose filter with my Taylor 2006 test kit. Results: FC - 0, PH - 7, TA - 250, CH - 150. Should I go ahead and use the well water to fill the pool?
How do you test for iron? I know our house has some pretty serious water softening equipment for the well water.
Take the water to the pool store for a metals test.
I assumed your ECO ONE hose filter filtered out iron.
ECO ONE hose filter
Hose filters are really expensive chlorine removers. Yours filters to 20 microns which is somewhere between a sand filter and carts/de.
We'd be having members pump through them if they removed anything else and nobody would spend $1000 on RO or drain/refill their pools. Yours claims it could do your pool 4X.
