- Jun 21, 2020
- 829
- Fiberglass
- Jandy Aquapure 1400
Ok, I my pool is about halfway filled. My PB had put shock in because there was some green algae in the pool when it had about a foot of water in it for about 10 days. They finally got going with my build really this week and started to backfill gravel and added about half the pool depth with water. They added shock when I wasn't home. I added 36 ounces of 12.5% bleach this afternoon. 3 hours later I took my first sample of water and just tried my chlorine test.
Ok here is the issue, I added 10ml of pool water, then put in X speed stir thing and opened my R-0870 powder. It was like dried cool aid. I have the XL size kit so I have 2 of the R-0870 so I opened the second one, same thing. I just got this kit about 3 months ago and its been stored in my dining room buffet. I banged both little containers around to loosen the powder and put in a heaping blue spoon (blue spoon from kit) and put in water and turned on speed stir. Water did not turn pink at all, zippo. Should my powder look like my picture below, both bottles look that way. The 2nd one I just opened for the first time. All stored in cool dark place. This is the exact same thing that happened when I tried my tap water when I got my kit but assumed zero chlorine as I have full house water filter that purifies the water so assumed no chlorine. Now with my pool how could that be no chlorine. Could all of the chlorine been used up in 3 hours. Assuming 9000 gallons (which I am being conservative on a 17,690 gallon pool) the pool app tells me the effect should be that FC is 2.6. Could it really be zero?? BTW is it 10ml before you drop in the speed stir X thing, I am assuming so?
