My pool is 18 round and was thinking of using 2 4x8 pillows this year and not draining below skimmer. The idea is to keep water from pooling on and subsequently leaching through the cover.
I bought a brand new (not cheap) solid cover last year and water still leached through. So I was pumping pool water off the cover all winter and had to add A LOT of water around February.
Last year I drained below the return. The year before I didn't drain. Both times I lost pool water to pumping the cover, but obviously the water level was much lower last year. This just seems stupid. There has to be a better way.
I thought about building a frame out of light PVC (maybe electrical conduit) that could test on the pillow and extend onto the pool rails to create a tent-like frame. Then lay the cover over it. But could possibly get the same results using extra pillows.
So what should i do? What could the problem be with this idea? Heavy snow? That's the only one I can think of but I'm not sure if it would be a problem.
