Hello all. Newbie here but very avid DIY’er. I just upgraded to a 16x32 intex ultra. Big step up for me. I’ve got all my plumbing laid out and ready to glue. I have a quick question however. The DIY PVC 1 1/2 with 1 1/4 reducer bushing looks good and I’ve found the relevant pieces at Home Depot. Lowe’s reducer bushing doesn’t have enough of a lip.
While dry-fitting the DIY adapter It really seems like there just isn’t enough spacing to really be able to tighten the collar down onto the pump. I assume there’s no need for an additional gasket as the Intex Sand/SWG system has a nice thick gasket already. But if so that would be even less room. I actually took one of the bushings and very carefully used my chop saw (has a laser line so I know exactly where I am cutting) to trim it down about an 1/8 of an inch. This is best done with the bushing very snugly inside a 2-3 foot section of 1 1/2 pvc pipe so it can be held sturdily and safely in place. Still leaves me plenty of lip but did give me significantly more bite on the pump’s threaded pipe.
Are people having leak issues? Are they able to tighten the collar down enough without shaving things down like I did?
Just debating whether I reconsider and maybe get a 2” female threaded coupler to slip with a 1 1/2 reducer. Although that method takes out the gasket and you get no help from having the gasket there.
Thanks in advance. Getting ready for summer here in NC. I’m sure I’ll have lots more as I fill this beast with water and start getting ready to have people over.
Jim
Jim
