I wanted to start a separate thread from our build thread to see if others have dealt with our issue.
I wanted to use Lightstream glass tile as the entire waterline tile but the cost of the tile and the labor just made it too costly. The design woman at the pool supply store (where PB sent us to pick out materials) suggested using the glass tile as an accent tile on the waterline by having one of the 6x6 tiles every 4 or 5 tiles. It was a good compromise and saved us over $3000. We found a ceramic tile that compliments the glass tile beautifully and even better was that it wasn't an upgrade.
A few days ago we received the shipment of the ceramic tile and I was setting some out and placing my sample of the glass tile in line to see how the waterline would look when I noticed the tiles were 2 different sizes.
I figured tiles had a universal size much like lumbar. A 2x4 isn't a true 2 inches by 4 inches but regardless of where you buy it, it will be the universal size.
Turns out the ceramic tile is 5 13/16" and the glass tile is 5 15/16". While it doesn't sound like a lot, when it is being set in a straight, level line, you will def notice the grout line being un level.
My first thought was to level the bottom edge in the water and have the unlevel part be up top since the coping and ledger stone at the spa stick out and would hide the top edge. Plus not a lot of light gets up there so wouldn't be easily seen.
However, one problem is that on the back edge of the pool we have a 2 foot tall 10 foot long accent wall. The front of this wall is going to be tiled with the Lightstream tile and directly buts up to the waterline tile. So if the top edge is unlevel, it will def show on the wall.
If we do the unlevel grout on the bottom, I am concerned that it will drive me nuts bc you can see it.
The solution I came up with was to only use Lightstream glass tile as the waterline tile where the wall is. That way the grout lines would all match up. However, the waterline will now be 4 ceramic tiles, 1 glass tile everywhere until the wall where the waterline changes to all glass. Will this look too odd?
If we go the route with glass waterline just at the wall, the issue is now that I need 8 actual glass tiles (2 sq ft) to be able to do this. These tiles are made to order and are supposed to be shipping out this week. Still waiting to hear back from the rep there about getting 8 tiles added even if they are just samples.
Any thoughts? Has anyone ran into this issue personally and if so, what was your solution?
Here are the pics showing the difference
Uneven side
Showing this side is flush
Showing how the waterline is going to look with the 2 tiles
Uneven side
