- Jul 10, 2020
- 161
- Plaster
- Pentair Intellichlor IC-40
Do folks with an SWG try to keep a small supply of liquid Chlorine on hand for emergencies & supplement the SWG before the CL goes bad or do you only buy it as needed given its limited shelf life?
We opened our new plaster/SWG pool in early May using liquid chlorine to make the pool swimmable prior to adding salt and turning on the SWG. I still have two unused gallons (12.5%) in the garage. If the useful life is about 2 months I'm considering turning down the SWG and using up the liquid Chlorine so it doesn't go to waste.
We are are still trying to figure out the optimal % setting for the SWG. Only once has our pool hit the low end of the acceptable FC range using the SWG so I have not yet had a need to use liquid CL to boost FC. I've been conservative in tweaking SWG output by erroring on the side of letting it get higher rather than lower. We had 4 days of high usage over the holiday weekend with a lot of sunshine and high UV so I assumed that FC levels would plateau or even drop but that didn't happen. Right now FC has climbed to the high side of 9 so its a good time to scale back the IC40 & use up the CL.
What are TFP users' strategies for using Liquid CL with a SWG pool?
