Use IntelliPH without IntelliChlor ?
Jan 13, 2015
59
Las Vegas, NV
Hi,
How can I use the IntelliPH without and IntelliChlor attached? I moved to fresh water but still looking for autofeed of the acid since it still requires it every few days. I'm not worried about too much, I'll adjust it to it can go a couple weeks without needing to add manually.
Thanks.
Have not actually tried it, but looking at the trouble shooting I would say no, not directly. The salt cell has to be on, flow light green, and dispensing for it to work. If you are into electronics you could build a dummy that it would think is working. OR..............
That said you still have a tank and an acid pump, and a power supply.
Just power the acid pump through some kind of timer and you are golden. If you have a easytouch or Intellitouch, you can take power from the same power supply transformer run it through a contact and power the acid pump. Then just run a schedule on it.
I am soooooo good.
I was wondering if someone built a fake connector to make it look like a working intellichlor. that be cool. As far as a timer, do you know the voltage and wiring?
using tabs for the CL, installed out of line Hayward. The inline restricted to 1" and don't want any limits for when the floor cleaner comes on.
