The Intermatic PE103 is designed to be used for dual speed pump timing. (http://www.intermatic.com/-/media/inriver/7101-8546.ashx/P103%20Instructions)
I have a variable speed pump which the speed is controlled on the pump, so it is wired as if a single speed pump. I also have a pair of T104 timers which are in really sorry shape. Could I use a single PE103 as a replacement and wire the pump to low and the cleaner to high? This would ensure the pump is on while the cleaner is on. I could even use the remaining aux for light control.
To wire, If you number the terminals from 1 - 10 (left to right), I would connect:
Line 1: 1,3,5
Line 2: 2,7,9
Pump1: 8
Pump2: 6
Cleaner1: 8
Cleaner2: 4
Light (120v): 10
I also have a salt cell that would be wired in parallel with the Pump1 and Pump2 connections.
The only problem I could see is that when the Controller is on low, Cleaner1 is electrified to the cleaner pump, even when the cleaner is off. Is this against best practices?
Garrett
Line 1: 1,3,5
Line 2: 2,7,9
Pump1: 8
Pump2: 6
Cleaner1: 8
Cleaner2: 4
Light (120v): 10
Garrett
