Opened pool April 3rd, which is my very first spring. Things seem to be going well. Tested early this morning right before sunrise after adding last night to prepare for the overnight test.
FC - 7.5
CC - 0
CH - 350
TA - 90
PH - 7.8
CYA - from previous test is 40 from 11 days ago. CH has stayed the same. TA dropped from 110 to 100 to 90. Getting better at testing? Naturally sliding down? PH continues to be 7.5 -7.8 Couple of observations. One, it rained all day and as very cool on Friday. The sun never showed itself. My testing showed I did not lose any FC. I had added on Thursday night to get to my target of 7.0 and Friday night testing showed it stayed there. Yesterday, was full bright sun. I tested at sunset and lost 3.5 of FC. It made me pause. I added LC to get back to 7.0. May have slightly overshot it because I was to add 29 ounces and test results showed 7.5 a hour later and again this morning. I am using 8000 gallons on additions and so far seems pretty good. Following revitup on his similar path with pool capacity. Anyway, tested at sunrise this morning and FC stayed the same at 7.5 and CC was 0.
So my pool is full sun. So I’m thinking I could increase my cya to 50 or use the solar cover to limit uv rays during the day to add a bit more protection to the FC. I’m digging through the forums and read that rate of FC loss from sunlight is fairly independent of the temperature of water per chem geek. I’m just tying to learn the process, my pool, and anticipate daily FC loss now, but also in the summer. Normal to lose 3.5 of FC on cloudless bright day in spring? Pool water looks sparkling clear. I’ve ordered the speedstir to hopefully increase testing accuracy. I’ll stop rambling now....
FC - 7.5
CC - 0
CH - 350
TA - 90
PH - 7.8
