Hi All,
We are currently filling a 24' x 52" round pool (actual water depth will be around 44 "). We have a pretty decent slope in our back yard so I spent 3 days over Memorial Day weekend tilling and shoveling dirt to try and level the ground. I used a 12' long 2x4 with a 3' level to check and everything looked to be pretty level. Now that I am filling it I am seeing a 3.5-3.75" difference between the highest and lowest points. I would say the high spot is only covers about 1/4th of the circumference of the pool so it's not like the low spot is purely concentrated on one area (the difference is 2"-2.5" on the sides). I'm not sure how it was this off, and I wonder if it really could settle that much?
And what if I only fill to the "fill line" on the low side leaving the high side to be more shallow?
Cause for concern?
I also see other posts where people used something under the uprights.... mine are on the ground as the manufacturer instructions made no mention of placing anything under the footers for support. In hindsight it was probably a good idea but I was getting a lot of pressure from my wife and kids to get the pool up and it is my first time setting one up. .
More than anything, there seems to be a pretty wide range of opinions on leveling so I'm trying to determine where the tolerance level is where I can still feel good about how it is set up.
TIA!
Donny
Cause for concern?
TIA!
Donny
