After increasing need of topping up our pool, we reached the point where we have to acknowledge we have a leak. This has been confirmed at 1/8 to 1/4 inch a day (evaporation is not a factor, solar cover is on and pool is indoors).
When we were losing less than an inch a week, it wasn't too concerning (and could easily have been evaporation), but now that we lose a little more, at some point we'll probably have to get help to find it.
What we have done so far:
- using a mask, a weight to hold on to, and food colouring, checked likely suspects - light, surface cracks, skimmer, main drain (nothing found)
- let the water drain down below the skimmer opening. The water has just fallen below - it's now 1/8 below the skimmer opening on the pool side, but in the skimmer, still full (this seems like confirmation that it's not the skimmer)
- water loss seems the same with the pump on vs. off (not confirmed - planning to do so).
So, I'm realizing I probably need to call in a leak detection company - but is it severe enough yet that a) it's warranted and b) they can find it? At this pace the water is falling too slowly to just wait to see where it stops.
My last step will be to dive down and plug the main drain, as well as the return, just to be sure it's not those. We have no hydrostatic valve in the drain.
Summing up, three questions:
1) Is it severe enough that I should call somebody in?
2) Will they be able to find it, at the current leak rate?
3) Did I miss anything obvious?
Thanks for the help!
