- Aug 27, 2024
- 6
- Plaster
Moved from old thread HERE
[Yes, of course, it would wonderful if every installation had conduit with cable that could be pulled through, but this is the real world!]
May I ask how your splicing turned out? I just ran such a question through ChatGPT, and the answer was pretty good (attached). But I'd love to learn from your actual experience. My splices to date have worked poorly. Plus the non-bulb, circular disk style LED pool lights that my contractor used (i.e., no lamp niches) continuously fail. So this is an ongoing problem. First, I'll try to extend the cable.My 10 meter pool was blessed with six pool lights by my builder. Great for swimming laps, but overkill. A decade later, those lights are failing from UV, chemicals and general shoddiness. They are not easily replaced, but I have found some on Amazon that seem similar. Amazon.com : Eapmic 12V 25W Pool Light Underwater Color-Change LED Lights RGB IP68 with Remote (25W) : Garden & Outdoor
The problem is that the existing lights are cabled through a lot of concrete back to the equipment room. Thus, the new lights have to be connected by snipping the original cable and splicing them into the new underwater. While I am not going to electrocute anybody with 12 VDC, I would prefer the current go to the light rather than dissipate in the water and have connection electrólisis.
Any thoughts on a truly watertight connector (small has to fit behind light) that I can use to join these cables?
Your thoughts appreciated.
Peter
