Understanding differences betwen CYA 60 vs CYA 70
Jun 26, 2017
71
Tulsa, OK
60​
5​
7-9​
24​
70*​
5​
8-10​
28​
In both cases the minimum FC is 5. Can someone explain the difference in target level that is mentioned? 7-9 vs 8-10
If the pool is losing say 3ppm per day, at both CYA levels we would be targetting 8 or 8.5 right? So what is the actual difference here?
We were at 70, 3 - 4 weeks ago. When I hit 60 , what would we do differently in regards to chlorine additions is my doubt.
Thanks.
The minimum FC is always 7.5% of CYA, so for 60 that's 4.5ppm so they just round up to 5ppm. For the 70 row, 7.5% is 5.25ppm so they just round to the closest integer, i.e. 5.
You notice all the recommended range are defined as 10% of the CYA + 2ppm. then just plus or minus 1ppm to define the range. So 60 the range is 8ppm plus or minus 1. And at 70, the range is 9 plus or minus 1.
As you've noticed there's not a lot of difference between 60 and 70 and they have somewhat overlapping ranges.
