Hello why can’t I ever get my water balanced right? I have dry stabilizer in a sock but I lose so much chlorine all the time, my AK is is very high also. And my ph is right at 7.8…CH is high too. But a couple weeks ago everything was perfect.
Taylor K-2005 maybe? Might think about adding the fas-dpd testing kit which is more accurate...Taylor K-1515C.I don’t know how to do my signature thingy but I have the Taylor K-2500 testing kit.
You may need more chlorine on a daily basis. Your target FC should be based on your CYA levels. Always follow this...Link-->FC/CYA LevelsHere’s my results. We have a cartridge filter system. I just use Liquid chlorine from the hardware store.
FC-.5
TA-210
PH-7.8
CYA-30
CH-650
Could be, in MN your loss shouldn't be more than 4ppm/day. More likely, you need the FAS-DPD test kit, and test and replace FC daily. Increasing CYA to 50ppm will decrease your FC usage.My pool is a 24 ft round pool. Maybe I need way more stabilizer?
Yes, we recommend testing and replacing FC daily.Feels like if I don’t stand guard and baby the pool everyday it goes south so fast.
Cartridge filters are one of the best filtering systems. It is your chemistry, not the filter.I brush it about every other day and vacuum couple times a week. It’s clear right now but it’s not gonna last when my FC is at 0.5 only!! And it gets really dirty. Maybe it’s the dumb cartridge filter system we have.
