Hi, I tried priming my pump but water doesnt suck from the main drain into the pump. I have a star right canister filter. The manual mentioned to open the air relief valve during start up. The pump works. I've tried to fill the pump basket with the main drain valve open and closed while slowing opening the valve, neither option worked. There are two main lines to the pump, one from the drain the other from the skimmer. The skimmer valve is closed since the water line is lower than the skimmer. The skimmer basket port has two holes. Both are unplugged. The first pic is my setup. The second pic is of a plastic plug that was left over. An identical plug was used to plug a pipe from the heater. Hope you can help this first timer.
