Hi guys- need some advice. I bought this cover and plan to install it using tie down stakes in the ground vs screwing into my plastic support columns on above ground pool. It’s also known as Armor Kote Ultimate pool cover.
The cover has a mesh strip down the middle to allow water to drain into pool vs sit on top. I don’t mind cleaning one row of silt at bottom of pool in spring. So here’s my quandary. I’m in New England with snow and freezing temps. The cover is meant to be tight and not to use a pillow in middle because it’s self draining.
1. Do I use a pillow anyway because of freezing temps and expansion issues on wall?
2. How much do I drain the pool water? It says that rain will overflow via skimmer but last year I used a skimmer cover with a regular cover with pillow
Any advice would be appreciated?
