- Jun 1, 2018
- 16,000
- Vinyl
- Hayward Aqua Rite (T-15)
I decided to remove/dump my leaf net today & saw that one section of my wall is pushed in on the side that is the most buried. It is slightly separated from one of the uprights. There are places which I could probably stick my entire arm between the pool wall & the surrounding ground in a couple places. We added more backfill & gravel in that area along with putting gravel around the entire pool last season because the original backfill had settled so much so we were trying to remedy the water shed issue which I believe previously caused some wrinkles to form there at the cove. Iāll post a couple pictures but its hard to truly see on them.
I have been refilling the pool today to prepare for āsoft openingā aka - run the pool with the cover on until the pods are done falling.
I do believe at one point recently the water level in the pool got too low due to the cover pump pulling water through the cover but I remedied that as soon as I realized. This obviously allowed for some shifting of the wall because of the newish backfill.
The cover is still on - I am scared about what I will see when I remove it. I will update when I do.
The wall is wet because weāve had alot of rain but you can see the separation from the upright. The deck sits almost on the ground in this area so I canāt hardly get the camera in there
Assuming everything is in the top/bottom tracks when I can get an inside look is it possible that the water will push the wall back out? Externally, from what I can see, there are no creases.
@Casey
@Casey
