I have this one
With 9 Whirlpool jets and seating for 5, the LS50 has a unique bench seat configuration. Also includes a waterfall, LED lighting & thermal friction heating.
outletspas.com
I paid $1800 for it a few years ago on wayfair.
It was worth every penny.
My climate makes the 110v aspect not really a problem- that said, last year during the “polar vortex” & 1 degree days I used it every day. I keep mine at 104 degrees & stay in until it drops to 99 or 100 when it’s cold outside. It always makes it’s way back up to temp by the following morning/evening when we are ready to use it again.
Since it’s rotomolded me & my teen daughter can move it easily when it’s empty. Since it’s round I can put it on it’s side & roll it if necessary (although I don’t really have anywhere else to put it).
The shape also helps it fit less intrusively on my patio.
The jets & their accompanying force are plenty strong enough for me, when both me & the hubby are in it he gets the back jets. The rest are just singles. I had used a couple different roto molded ones @ vrbo’s so I knew what to expect. I figured it would be our “starter spa” & if we liked it & used it we could upgrade to something larger & more robust & expensive later.
It has been a great experience, we use it pretty much daily (sometimes twice a day) except in the very dog days of summer where it’s 100 degrees at night. In the shoulder seasons for the pool it gets a lot of use, swim/float a little then warm up in the hot tub. This helps extend our pool season.
As mentioned above you really should have a dedicated gfci circuit whether you get a 110v or a 220v tub even if it’s an intex kind of tub.
The inflatable ones aren’t horrible for the money if you get one for $200-$300. They are just not a great substitute for the real thing & they have their quirks.
They do have their role & that is to determine whether or not a hot tub is something you will actually use for little coin whilst being storable if that’s a thing you require.
In your climate & with a small budget I recommend a plug & play that has the option to be either 110v or 220v (220v allows you to have heat & jets at the same time w/120v it’s one at a time)
Or a nice used one you can verify is operational as mentioned above. There are several offered here everyday on fb marketplace.
