Turned Multiport with Pump Running
Oct 17, 2018
2
VA
In my haste to dump an overflowing pool from recent rains, I turned my Hayward SP0714T Vari-Flow Multiport but forgot to shut off the pump. I realized my error within a few seconds and shut the system down as I reached the closed position on the valve. When I turn the pump on, the filter basket no longer fills as the pump does not appear to draw water from the pool. No unusual noises from the pump. I have turned the multiport 360 degrees both clockwise and counterclockwise without success to correct if valve was just misseated. I am hoping I just need to replace the ground key/seal assembly (it's the awful one with the seal glued to the gasket that takes a vise to attach to the handle). Any other thoughts?
