Turn off Jandy SWG that is using Aqualink
newpoolj
129
Sacramento, Ca
I have a Jandy SWG that is in need of repair, as it's clicking on and off internally every few seconds and saying "check cell". I'd like to turn it off so that whatever relay is clicking on/off doesn't get burnt out, but the normal way of holding down the power button doesn't work. Instead the screen says "JandyAutomation". Is there a way to turn off a SWG that's being controlled by Jandy automation?
Can you set the generation % to 0?
Try disconnecting the wire leading to the Tri-sensor.
