Hello, I'm trying to understand my results from the block.. The color seems so much darker and brighter than the highest on the key. Does that coincide with the results of the drops? I assume it does but seems really dark/high on the daily test vs the weekly test.
Out of the results below I interpret them as you see to the right of it. I will just add what's recommended for each from the calculator.
10/26/2024 - 11AM EST, 84F
Free Chlorine = 30 ppm (currently high)
Combined Chloramines = 0
Total Chlorine = FC+CC
Calcium Hardness = 125 ppm (low)
Total Alkalinity = 120 (currently high)
CYA = 80 (currently high)
pH = 7.6
Cl Br = 10+ (?)
Temp = 80F
Thank you
pH = 7.6
Cl Br = 10+ (?)
Temp = 80F
Thank you
