Hi all,
Weird question, I'm back and trying to set up my "new" pool. We moved into the new house, the previous owner had a 500-gallon propane tank buried in the backyard. A gas contractor stopped by and said the tank is in full working order, however, he doesn't do the installation. The tank at this point is not connected to anything. It was originally connected to a pool water heater, but the original owner said he replaced the heater to electric.
I will be running an underground polyethylene line for about 80-100 feet. What size regulator do I need?
I'm planning on using a first stage regulator (like this one), then run the line and use a second stage regulator and finally connect my kitchen which already has a built in regulator and also a Pentair 400k BTU heater.
Thanks!!!
Thanks!!!
