Troubleshooting new Vingli
DrRichardson
1
Sacramento
I have new Vingli pool vacuum. After a while it stops oscillating and just sits there. If I give it a nudge it may start up again, but only for a while. I believe it's supposed to oscillate so long as there is water flowing through it. I don't suspect low flow volume because when it's working it works quite vigorously. The regulator is turned to max. Maybe there are a number of things I can check?
What pump are you using? A VSP?
RPM too low? Dirty filter? Clogged pump basket? Clogged cleaner hose?
Please don't expect too much from a cleaner that only cost about $100.00.
