Hi Everyone,
I was vacuuming the old pool the other day, and noticed a significant loss of suction at one point. I went to check the pump and noticed it wasn't fully priming. Originally I assumed it was something that got into the skimmer line (I was vacuuming directly into the skimmer line like a dummy without using the skim vac) and there's a solid chance a dead frog or pecan or something got in the line. I tried flushing out the lines but that didn't seem to make a difference. I've gone through a few other tips like using a hose and checking to see if any of the suction side connects are sucking air in, replaced the pump gasket, took the thing off and cleaned out the impeller. One thing I've noticed that seems peculiar to me is that once I turn off the pump, water rushes from the filter back into the pool pump. To me, that would seem to indicate there is a buildup of air pressure at the top of the filter pushing that water back, but I've bled the filter and it still does that. I've also tried flushing the lines using a hose bladder, inserting it into the pump and flushing it back to the skimmer, using a tennis ball over the skimmer hole to alternately build up pressure then release. Pool shop is closed until the middle of next week with the holiday and I'd like to have it running for the holiday.
Any ideas?
Any ideas?
