We use the sock method for a couple reasons.Thanks for the info guys and hopefully we are almost there. I just put the CYA sock(s) in the pool and had to use a couple since I was putting in about 6.5lbs. The CYA container said to sprinkle the granular material throughout the pool but I obviously used the sock method. Does the sock method allow the CYA to start working right away or will it take several days to have CYA reach 30ppm? I just did the first SLAM with liquid chlorine and will monitor results after a couple of hours. I'm fully expecting the FC to come back down to low single digits and will SLAM again this evening most likely. I feel like a scientist!!
1) If you need to backwash before the stuff is dissolved and you poured it down the skimmer the way some brands say, you just lost it.
2) If you scatter it on the floor, you might discover white freckles later, as CYA is acidic. This applies to vinyl and concrete both.
3) If you scatter it and then vacuum, it all ends up in the filter. See #1.
When the sock is empty, you have 30 ppm. Traditional wisdom has been that you wait a week to test. There has been much debate about that. A week may be too long, but next day may be too soon. Just assume the calculated value is there until proven otherwise. You'll be rebalancing the water after the SLAM, so test it then.
