Hi everyone,
Thanks for the forum and advice so far. I have been reading through a lot (information overload) and have bought the Clear Choice Labs salt water testing kit. Have done a couple of tests and compared with the results from a store test, some differences but not too badly out. However....
Today I did a test with the following results:
FC - 29
CC - 0
pH - 7.8 (test max - last store result and controller shows >8.5)
TA - 120 estimating (last store result was 105, result from todays test showed over 300)
CH - 275
CYA - <30 (5 based off last store result)
SALT - 6800 (3125 last store result) - I haven't added any salt so this seems super weird
Temp - 31C
CSI - 0.16
Over the past 4 days I have added 5 litres of MA (29%) with no reduction in the pH levels. I am concerned about adding in too much due to the smell/taste of the water. We don't use the pool for 1-2 hours after adding but as the pool is indoors, there is a distinct metallic smell in the air and taste to the water afterwards.
Previously when the pool installer added MA (by hand and through the controller feeding system), the smell was very strong and our skin ended up in a rash and itching like no tomorrow, so I want to avoid that happening again.
The FC is really high, I have turned down the SWCG to 20%, wondering if I should bypass it and have the pool on recirculation instead for a while. Need to keep it heated as the reason for getting it is to help my wife with chronic pain.
Last backwash was 5 days ago, along with vacuuming to waste due to a white powdery coating on the pool floor that I thought might be bi-carb but wasn't soluble.
Any advice/suggestions appreciated.
FC - 29
CC - 0
CH - 275
Temp - 31C
CSI - 0.16
