I have a tumorous kidney shaped pool. According to my builder, the volume is "approximately 34,483". I've been operating off of 34,500.
I'm about to add salt for the first time and want to make sure the volume I'm using in poolmath is accurate.
I waited until dark and tested.
FC: 4.5
CC: 0.0
I add 70oz of 6% LC which according to poolmath, would increase FC 1ppm in a 34,000 gallon pool.
I tested again after 45 minutes.
FC: 5.5
Good to go. My volume looks spot on.
BUT, at the same time, I also tried testing with a 25ml sample which would give me a 0.2ppm per drop test. I figured that would give me a more accurate test for checking my volume. First result was FC: 4.8, second was FC: 6.4. That's a 1.6ppm change which poolmath says could only result in a 21,000 gallon pool based of the addition of 70oz of 6% LC. That's pretty far from 34,000...
I'm thinking the normal 10ml test results are good and they align with the builder's estimated volume. But I'm curious if the 25ml test is suppose to be more or less accurate. Or if I jacked this all up from the start...
FC: 4.5
CC: 0.0
FC: 5.5
