Treo Lights
jmtaylor1228
Active member
Oct 20, 2020
31
Central NJ
Hayward Aqua Rite (T-15)
First year with a pool. Our liner is too big so we can't drain it too far. As a result, we can't drain below the Treo LED lights. The builder installed them after the pool was filled with water. I went to pull the lights and the connection is not coming out and the line is tight so I think the electrician really did a tough pull on them. I called the builder who said that when they close they just leave the lights in and not to worry about the water. Anyone else have experience? I would have thought the water in the conduit would expand and crack the pipe, but the builder said it expands to the path of least resistance. Thank you.
