I have three 1.5" runs coming back from the pool on the suction side, two skimmers and a main drain. I have to re plumb the suction side of the pump due to the crappy red handled PCV valves on each supply. I have three 1.5/2 neverlube valves.
The pump is a Pentair WFE-4 with a vGreen 1.65 motor. It is currently 1.5" all the way to the pump. When I re-plumb the pad I'd like to use 2" between the pump and the three 1.5" supply lines. So create a 2" manifold that tees them together and runs to the pump inlet.
My question is where to step from 1.5 to 2"? My valves take both diameter, 1.5 on the inside and 2 over the outside. Should I use the valve to transition to 2" (my first thought), or 1.5 both sides of the valve and put 1.5 to 2" adapters in the tees at the manifold?
