Gunite pool looks pretty good but three tiles around inside perimeter of pool popped off recently. Tiles are about 4" square and are thankfully intact. I purchased mastic, but am unsure if I should get a chisel or grinder to remove old material so tiles will be even with surrounding tiles. I understand I will need to drain pool down and have surface clean and dry before attempting the repair. See photo. Suggestions?
