- May 25, 2007
- 43
- Plaster
- CircuPool RJ-60 Plus
Hi,
I am finishing up the process of cleaning up the waterline area where I need to retile. I want to make sure I got things straight before I proceed - is the red arrow pointing to a mud base or thinset, and the yellow arrow pointing to the bond beam? It almost doesn't look like I have a mud bed here, unless the thinset was laid very thin - what do you think? That area is varies between 1/4" to 3/4" in various areas around the pool.
If there isn't a mud bed, am I OK to tile directly to the beam? Or do I need to add bonding material and or Hydroban to the beam, then thinset / tile?
I'm following the guide here:
Waterline Tile Installation
thx!
Jerry
thx!
Jerry
