Thump noise coming from my skimmer basket
nabril15
668
Miami, FL
CircuPool RJ-45
Hello and warmth to all
My water level is below the tile line as I await rains some day here in Miami. As a result, I obviously turned off the skimmer suction valve when running my pump. However, when the pump runs, sucking 100% through the main drain, I hear a constant "thump" or drumming noise from the skimmer hole.
Is that because there's an air leak in the plumbing somewhere? I had never heard it before in the same situation of low water.
Thanks
The skimmer suction valve may not be sealing completely.
Show us pictures of your equipment pad and valve.
Reactions: nabril15
That's what I assumed, and air is getting sucked every 2 seconds = thump every 2 seconds.
Here's the pad
Impossible to know the condition of the ball valves. We recommend diverter valves be used as they are maintainable.
You can ignore the thump and hope for rain soon or add water to the pool and see if the thump goes away with water in the skimmer even when the valve is closed.
Reactions: nabril15
Too difficult to replace them, but I like the 2nd paragraph
I filled up the skimmer area to 75% full this morning, and now I see it completely dry, therefore and "ergo" there is some suction going on.
That's what she said
